Oct 31, 2022 6:35 AM UTC
Im stuck here while creating any WTPart Im facing this alert
java.util.NoSuchException alert is showing Please let me if any solution is there.
avillanueva
23-Emerald II
Oct 31, 2022 11:06 AM UTC
Can you post your OIR for WTPart in this area? I think its having an issue processing some of those rules.
Oct 31, 2022 7:11 AM UTC
Have you checked the Methodserver log for detailed error message? if yes please share the error message.
Also is this error with OOTB or customized Windchill instance?
Oct 31, 2022 10:11 AM UTC
Thanks for the reply @Devidas(Devi) Yes its with OOTB or customized Windchill instance
Method server -
ERROR : com.ptc.jca.mvc.controllers.ActionController wcadmin - java.lang.reflect.InvocationTargetException java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.ptc.netmarkets.util.beans.NmCommandBean.execute(NmCommandBean.java:2247)
at com.ptc.jca.mvc.controllers.ActionController.executeWizardAction(ActionController.java:222)
at com.ptc.jca.mvc.controllers.ActionController.processRequest(ActionController.java:125)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:190)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:138)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:878)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:792)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:652)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at wt.licenseusage.licensing.LicenseFilter.doFilter(LicenseFilter.java:47)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at com.ptc.core.ui.validation.URLValidationFilter.doFilter(URLValidationFilter.java:86)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:104)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:301)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1677)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:57)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:364)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:526)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1639)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: wt.rule.RuleException: java.util.NoSuchElementException
Nested exception is: java.util.NoSuchElementException
at com.ptc.core.rule.server.delegate.init.TypeBasedInitRuleApplier.applyRule(TypeBasedInitRuleApplier.java:348)
at com.ptc.core.rule.server.delegate.init.TypeBasedInitRuleApplier.applyRule(TypeBasedInitRuleApplier.java:212)
at wt.rule.impl.StandardRuleService.applyRule(StandardRuleService.java:382)
at wt.rule.impl.StandardRuleService$1.notifyVetoableMultiObjectEvent(StandardRuleService.java:985)
at wt.events.StandardKeyedEventBranch.intDispatchEvent(StandardKeyedEventBranch.java:306)
at wt.events.StandardKeyedEventBranch.dispatchVetoableEvent(StandardKeyedEventBranch.java:255)
at wt.events.StandardKeyedEventDispatcher.intDispatchEvent(StandardKeyedEventDispatcher.java:304)
at wt.events.StandardKeyedEventDispatcher.dispatchVetoableEvent(StandardKeyedEventDispatcher.java:228)
at wt.services.StandardManagerService.intDispatchVetoableEvent(StandardManagerService.java:410)
at wt.services.StandardManagerService.dispatchVetoableEvent(StandardManagerService.java:303)
at wt.fc.StandardPersistenceManager.dispatchVetoableEvent(StandardPersistenceManager.java:2972)
at wt.fc.StandardPersistenceManager.dispatchVetoableEvent(StandardPersistenceManager.java:2952)
at wt.fc.StandardPersistenceManager.store(StandardPersistenceManager.java:1429)
at wt.fc.StandardPersistenceManager.store(StandardPersistenceManager.java:534)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at com.sun.proxy.$Proxy28.store(Unknown Source)
at com.ptc.core.components.forms.CreateObjectFormProcessor.doOperation(CreateObjectFormProcessor.java:98)
at com.ptc.windchill.enterprise.part.forms.CreatePartFormProcessor.doOperation(CreatePartFormProcessor.java:280)
at com.ptc.windchill.enterprise.part.forms.CreatePartAndCADDocFormProcessor.doOperation(CreatePartAndCADDocFormProcessor.java:120)
at com.ptc.core.components.forms.DefaultFormProcessorController.executeDoOperation(DefaultFormProcessorController.java:538)
at com.ptc.core.components.forms.DefaultFormProcessorController.performExecuteDoOperationAndPostProcess(DefaultFormProcessorController.java:342)
at com.ptc.core.components.forms.DefaultFormProcessorController.execute(DefaultFormProcessorController.java:263)
at com.ptc.core.components.forms.FormDispatcher.callControllerExecute(FormDispatcher.java:146)
at com.ptc.core.components.forms.FormDispatcher.callFormProcessorController(FormDispatcher.java:116)
at com.ptc.core.components.forms.FormDispatcher.execute(FormDispatcher.java:93)
... 62 more
Caused by: java.util.NoSuchElementException
at java.base/java.util.StringTokenizer.nextToken(StringTokenizer.java:349)
at wt.enterprise.EnterpriseHelper.getNumber(EnterpriseHelper.java:196)
at com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator.calculate(NumberGenerator.java:44)
at wt.rule.algorithm.RuleAlgorithmHelper.calculate(RuleAlgorithmHelper.java:116)
at wt.rule.algorithm.RuleAlgorithmHelper.calculate(RuleAlgorithmHelper.java:74)
at com.ptc.core.rule.server.delegate.init.Utils.getValue(Utils.java:1160)
at com.ptc.core.rule.server.delegate.init.Utils.applyTo(Utils.java:693)
at com.ptc.core.rule.server.delegate.init.Utils.applyToWithNoLogging(Utils.java:465)
at com.ptc.core.rule.server.delegate.init.Utils.applyTo(Utils.java:285)
at com.ptc.core.rule.server.delegate.init.Utils.applyTo(Utils.java:497)
at com.ptc.core.rule.server.delegate.init.TypeBasedInitRuleApplier.applyRule(TypeBasedInitRuleApplier.java:332)
... 90 more
avillanueva
23-Emerald II
Nov 1, 2022 6:49 AM UTC
Hey thanks @avillanueva  you said about OIR.
I was wrong in OIR that's why it was occurred.
3-Newcomer
Jul 3, 2023 5:54 PM UTC
im getting the same error, what you did on the OIR to resolve the Issue?
