Jun 26, 2023 9:17 AM UTC
Import/Export Part Structure using Name or another attribute except Number
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS11
How to use custom numbers and import a structure with autogenerated numbers using Import From Spreadsheet Action.
Fadel
FadelAnswer
23-Emerald II
Jun 26, 2023 1:13 PM UTC
Hi ,
if you are using auto numbering then you can omit the number column and and it will get number assigned from sequence as per OIR for Part creation
On the other hand for creating BOM (structure) we have to use numbers of existing parts in system .
so you have to use a 2 step process :
1- create part and get their numbers
2- create BOMs with numbers from step 1
Buiꓘa
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
Hi ,
Buiꓘa
