In Advanced Search, how can I make Attribute under 'Criteria' section as Auto Suggest in Windchill 10.1 ?
How can I make Attribute under 'Criteria' Section in advanced search as auto suggest or How can I hook a Data Utility for this attribute?
Is using a saved search out of the question?
Setting the parameter to your default, then adding the remaining parameters you normally search by would get you this OOTB.
