Invoke wt.load.util.CSV2XML and wt.load.LoadFromFile commands from a java code
Hi All,
I am trying to bulk load wtdocuments into Windchill for which I have the content files and the attributes (name, number, description, version, state, IBAs etc) in an excel file. The usual method for bulk load is to create a CSV using the data in the excel file, then create an XML from the CSV (wt.load.util.CSV2XML) and finally load the documents into Windchill using the XML file (wt.load.LoadFromFile).
I am trying to create a java file which will read the excel file with the raw data, create a CSV and subsequently the XML file using it and then finally invoke the load command using the XML file. Before I put all of these together, I am trying out each step individually and am not able to figure out a way to invoke the wt.load.util.CSV2XML and wt.load.LoadFromFile from a java file. Has anyone tried that? Any ideas?
CSV2XML. class present in Windchill,
de-compile it and save as CSV2XML_.java in your package.
simply call this CSV2XML_.main method in your class, it will convert csv to xml,
to LoadFromFile, use below
LoadFromFile.doFileLoad(filepath, null, null, null,cmd_line);
here, filepath= actual path of .xml file.
cmd_line = CONT_PATH.
Vivek
My scenario is same. we are migrating documents from network drives to Windchill 11.0. I want to know how to create a CSV (that can be used for CSV2XML utility) for bulk load using the excel file with attribute values in columns.
Many Thanks
