Is it possible to edit only few columns in 'Select Affected Objects' table of a Change task
I want the users to be able to edit only few columns(Comments or Disposition Comments), and make the other columns/fields read-only in this table. Is it possible with basic customization/configuration?
HelesicPetr
Hi @RG_10753677
Yes you can,
One option is to find a data utility that show the attributes and extends this DataUtility and set the read only  based on your conditions that can depend on a type wizard create/edit.
PetrH
