Unfortunately there is no supported API other to do that. See https://www.ptc.com/en/support/article/CS174385
Probably you need to write your own class to copy the object. Or you could try to save as the object? https://www.ptc.com/en/support/article/CS59135
not sure if that would work.
If there is no offical api, you may able to do it via creating your own servlet(Endpoint) class.
Catalina
Community Manager
Hi @SB_10904295
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
avillanueva
23-Emerald II
If the post was specifically about using a template, then I would say this is resolved since previous posts clearly answer that. There are ways to have a workflow (say in CR workflow) create the CN and other aspects but not via a template. I've done this for years and you can have it create the CN and the change task with default information. Nothing too special but I was not using a template.
