is there any api to get WTChangeActivity2 from Workitem?
Im trying to get all the change activities assigned to workitems.
@BjoernRueegg , @HelesicPetr
HelesicPetr
Hi @manoj_dokku2
If you need to get object which is related to WorkItem usually it is primaryBusinessObject
workitem.getPrimaryBusinessObject().getObject()
It can be any type in a system so you need to check a type and cast to the correct type.
WTChangeActivity2 WTCA22 = (WTChangeActivity2)workitem.getPrimaryBusinessObject().getObject()
PetrH
HelesicPetr
Hi @manoj_dokku2
Clarify your needs.
The WorkItem can have only one Change Activity.
Work item is a task for a user. One task can not be assigned to more ChangeActivities as WTChangeActivity2
PetrH
Hi Peter,
For example, if i have a workitem from the queryspec "QuerySpec querySpec = new QuerySpec(WorkItem.class);" with some conditions, i will be ending up with many workitems.
Is there a way to get a changenotice assigned to it?
Or for each and every workitem, can i get an associated change notice?
Thank and Regards,
Manoj.
HelesicPetr
I just add one point.
You really need to use a For or a While loop to get what you need.
PetrH
HelesicPetr
Hi @manoj_dokku2
PetrH
