18-Opal
May 7, 2023
Is there any possibility to create custom methods in custom email template for notification robot?
I need to have custom method in email template which displays the information related to the Object.
HelesicPetr
Hi @TDT
It is easier to write own code to send a email with your specific information.
or
What does the method should do ? Because if you need to just get information from windchill, then you can write the information to a workflow variable and then use the variable in the email template html
getActivityVariable varName="<Variable Name>"
getProcessVariable varName="< Variable Name >"
<SCRIPT LANGUAGE=Windchill>
</SCRIPT>
PetrH
TDT18-OpalAuthor
18-Opal
May 11, 2023
Hi @HelesicPetr,
Thank You for the response.
My idea is to add a new method either in custom template or OOTB template i.e. NotificationRobot.html.
All the methods defined in  NotificationRobot.html is using OOTB class NotificationRobotProcessor which is registered in service.properties.xconf.
I have extended the OOTB class and implemented a new method X and registered in .xconf file.
But I am getting an error that there is no method X.
HelesicPetr
Hi @TDT
Yes the registration can be in the xconf, but has been the change propagated to the service.properties?
btw I usually use simple way to achieve what I need.
There can be some another place where the methods are described what you can use in the html notification file.
PS> my experience is that if I wanted to reuse and rewrite OOTB function/method it cased more troubles. In the end I wrote own function.
PetrH
