Jun 20, 2017 8:59 AM UTC
Is there anyway to schdule?
I have a requirement where third party system is going to place a file on the shared directory. I need to pick the file in hourly basis and update the values in windchill WTPart.
Could you please let me know is there any job scheduler supported in windchill?
Jun 22, 2017 6:48 AM UTC
There is a full PDMlink solution.
Re: How to run background task periodically
You can also use windows scheduled tasks or crontab on Unix.
The trick is to create an Infoengine task to do the job you have to do with your WTParts.
No need to be an I*E expert, you can use pure java code in an I*E task.
Next, you can call your task with curl, from the OS scheduler.
curl -u user:password http://server/Windchill/servlet/IE/tasks/CheckFile.xml
To be callable from the IE servlet, an I*E tasks must have access="http" in its page tag.
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie" %>
<%@page language="java" extends="com.infoengine.SAK.BasicTasklet" access="http" %>
pros : Easy to manage from an admin point of view as it is driven by the OS
cons : The password is readable in the task. But it's on the server.
