11-Garnet
is there api to add multiple user to a role
Is there a api which lets us add multiple users to single role.
11-Garnet
I used this method and it works.
team.addPrincipals(HashMap map);
Catalina
Community Manager
Hi @SB_10904295
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • What version of product you're using?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill  looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
Fadel
23-Emerald II
some inspiration can be found below
https://www.ptc.com/en/support/article/CS355528
Buiꓘa
HelesicPetr
Hi @SB_10904295
Try to check following class and method.
https://www.ptc.com/en/support/article/CS138084
I guess that you have to use while/for loop to add more users.
or you can try following method but I've never use it.
addRolePrincipalMap(HashMap var1, WTRoleHolder2 var2)
PetrH
SB_1090429511-GarnetAuthorAnswer
11-Garnet
HelesicPetr
Hi @SB_10904295
Can you explain what values do you use in the HasMap input please? it would be useful for others.
Thank you
PetrH
