Issue in custom javascript method
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.2
Hello team, we are trying to propagate the custom.jsfrag file content using the below command-
ant -f jsfrag_combine.xml
but this command doesnt work. The issue we are getting is on one of our custom actions that have a corresponding javascript method attached to it.
Kindly provide us with a resolution for the same.
    Without any errors, logs, and a description of what you customized, it won't be possible to answer your question.
    18-Opal
    Wow, you’re really not going to tell anyone what the error is nor post your code so that we can find and point out the problem.
