java.lang.UnsupportedOperationException
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS08
PersistenceHelper.manager.delete();
객체 삭제 하면서 발생하는 에러.
Here are the errors that I faced
INFO : wt.system.err wcadmin - wt.util.WTException: java.lang.UnsupportedOperat
ionException
INFO : wt.system.err wcadmin - ?? ??: java.lang.UnsupportedOperationException
INFO : wt.system.err wcadmin - at wt.fc.collections.UnmodifiableCollect
ions$UnmodifiableIterator.remove(UnmodifiableCollections.java:895)
INFO : wt.system.err wcadmin - at java.util.AbstractCollection.retainAl
l(AbstractCollection.java:410)
INFO : wt.system.err wcadmin - at wt.projmgmt.StandardProjMgmtService$3
.notifyVetoableMultiObjectEvent(StandardProjMgmtService.java:552)
INFO : wt.system.err wcadmin - at wt.events.StandardKeyedEventBranch.in
tDispatchEvent(StandardKeyedEventBranch.java:298)
INFO : wt.system.err wcadmin - at wt.events.StandardKeyedEventBranch.di
spatchVetoableMultiObjectEvent(StandardKeyedEventBranch.java:263)
    18-Opal
    Hi @CL_9966509,
    What are you trying to delete?
    @GenAsPersistable(superClass=RevisionControlled.class,
    interfaces={ FormatContentHolder.class},
    properties={
    RevisionControlled  obj delete
    PersistanceHelper.manager.delete(obj);
    error
    Catalina
    Community Manager
    Hi @CL_9966509
    If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
    Catalina | PTC Community Manager
