May 1, 2024 9:05 AM UTC
Loader for Legal Value Lists
Version: Windchill 12.0
Use Case: Deployment Automation
Description:
Hi all,
As a part of deployment automation I wanted to know if there is any way to Export and Import Type Constraints especially Legal Value Lists easily. Like maybe a Loader file.
HelesicPetr
May 2, 2024 7:57 AM UTC
Hi @MV_10441462
You can automate the import of the softtype configuration by OOTB function loadfromfile.
https://www.ptc.com/en/support/article/CS30168
If you create type and attribute configuration you can export it and then use it for import many times you want.
It exports also all constraint settings.
PetrH
18-Opal
May 1, 2024 12:17 PM UTC
@MV_10441462
Yes, this is very doable.
I’ve added legal list constraints using a Java utility that I wrote.
Inputs are the Type, the attribute (that the constraint is applied to) , the list of values to be in the legal list.
Works by reading a text file with the appropriate inputs too, which I use for bulk loading.
Works well.
I have not tried to do an export but I would think that’s easier to write a utility to do that than to create a constraint.
May 1, 2024 12:27 PM UTC
@d_graham Can you share the snippet to add legal list constraint?
HelesicPetr
Hi @MV_10441462
PetrH
May 2, 2024 9:17 AM UTC
@HelesicPetr Thank you. Yes, just found that the export can be done using TypeDefinitionExporter and import can be done using TypeDefinitionLoader both programatically and LoadFromFile utility.
