Local attribute for EPM document
Hello there,
                 I want to create local attribute for EPM document but  I cannot create  local attribute for  EPM documents even though i added columns (using Add columns in windchill shell), but i can create local attribute for WTPart and Documents using Add columns, is there any way to customize the creation for local attribute for EPMDocuments or we cannot create local attributes for EPM documents???
I'm not sure standard (= local) attributes are supported on EPMDoument.
You should have a look on the PTC guide / help.
Why it is not supported??
He didn't say there were NOT supported.  He said he was not sure and that you should look at the help guide.
