Make listener update UI after doing modification at check-in on WTPart?
Version: Windchill 12.0
Use Case: Using a listener via API in order to update attributes at check-in of the corresponding WTPart / WTPartUsagelink.
Description:
Updating values of the attributes works perfectly, but after check-in using the browser UI, the new attribute values are not displayed on screen. The UI is not refreshed. Is there a command/hook or something that makes the web ui refresh?
If the user manually refreshes (hits F5), then the new values are displayed...
I tried those functions, but either wasn't competent enough or they are not made for this use case...:
// refresh for changes that might have been made to the object
working_part = (WTPart) PersistenceHelper.manager.refresh(working_part, true, true);
WorkInProgressHelper.service.refreshObject(working_part);
PersistenceServerHelper.manager.update(working_part);
PersistenceServerHelper.update(working_part);
wt.fc.PersistenceHelper.manager.save(working_part);
// this all does not help...
 Anybody have an idea?
18-Opal
Hi @SvenR,
Which event are you using, pre-checkin or post-checkin?
SvenR14-AlexandriteAuthor
@TDT pardon, yes, I should have mentioned that I am using
WorkInProgressServiceEvent.PRE_CHECKIN
as hook for the listener. 👍
18-Opal
Which API are you using to update or store the attribute value?
