Method to get Assigned Expression
Hello all,
I'm currently writing a custom JSP to summarise changes resulting from a Change Notice, I've managed to pull all the required data into the report except for Assigned Usage Expression (e.g. 'COLOUR= "GREEN"), which I'm struggling to get, does anyone know of an API method to retrieve this?
I've tried:
  • WTPartUsageLink.getExpressionData() - Returns null,  seems to just return the ExpressionData field from the WTPartUsageLink table,  which is completely empty, guess it's a redundant field
  • ExpressionHelper.getDisplayExpression(Expressionable,  WTContainerRef) - Returns "{Display : "" , invalid: false}", not sure why it's taking a WTContainerRef argument as this shouldn't make a difference to the returned expression, so maybe it's not doing what the method name implies.
CS384380 states that there's no supported API to achieve this, however that's not to say there isn't one available. Worst case, I could always build the expression through QuerySpec, but it feels like reinventing the wheel, if anyone knows of a method for getting the expression then it would be greatly appreciated.
Graham
HelesicPetr
Hi @GrahamV
It is not so easy to find the correct API
OptionHelper.service.getAllChoices(child, optionSet);
here you can see the API how to get options from your result optionset with wtpart. Also try to use the Usage link as a input
OptionSet optionSet = result1.getOptionSet();
WTList[] choices = OptionHelper.service.getAllChoices(child, optionSet);
Here is my working code
You can create reference from WTPart or UsageLink and combinate it.
ObjectReference ref1 = ObjectReference.newObjectReference(wtpLink); WTPartUsageLink
ObjectReference ref2 = ObjectReference.newObjectReference(subpart); WTPart
OptionSetDelegateResult result1 = OptionHelper.service.getAssignedOptionSet(ref1, ref2);
WTList[] choices = OptionHelper.service.getAllChoices(wtpLink, optionSet); // result for specific usageLink
PetrH
HelesicPetr
Hi @GrahamV
Where is the expression assigned? WTpart, UsageLink? difference place ?
Here are apis that can be used
//with WTReference
OptionHelper.service.getAssignedOptionSet(WTReference var0,WTReference var1);
//with colletion
OptionHelper.service.getAssignedOptionSets(WTColletion var1);
PetrH
GrahamV12-AmethystAuthor
Hi Petr,
I'm trying to retrieve the Assign Usage Exapression (i.e. the expression associated to WTPartUsageLink), though I suspect the same method will also work for other Expressionable objects like WTParts.
The methods you listed appear to get the Assigned Option Set rather than the Assigned Usage Expression, so I don't think that's what I'm after, it may come in useful though.
Graham
HelesicPetr
Hi @GrahamV
What Assigned Usage expression are you talking about?
The Assigned Usage Expressions are from the OptionsSets and the API retrieve it as you can see it in the Uses tab in the Structure.
If you use WTReference where you put usage link you will get what is in that usage link assigned.
Or you can put first reference as a parent and second reference as a child WTPart and you would get again the Assigned Usage Expressions
PetrH
