Multi-valued parameter using field params in the webject
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.7
Need help knowing how to pass the multi-valued parameter using field params in the webject (Update-Objects) for updating objects?
    Fadel
    23-Emerald II
    Buiꓘa
    Emeritus
    Hello @smanore,
    It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
