Need API to assign Option set to Configurable Part
Version: Windchill 13.0
Use Case: I’m trying to assign an Option Set to a Configurable Part. Can anyone help me with the API code for this?
Description:
joe_morton
It looks like there is some info on getting the assignment info: https://www.ptc.com/en/support/article/CS406283?source=search
But setting it might not be supported: https://www.ptc.com/en/support/article/CS413254?source=search
Community Moderator
Hi @AKC_82440,
Anurag
HelesicPetr
Hi @AKC_301264
It is just idea how to do so but it could work.
here is an example how the link could be created but it needs good testing if it is the right way
		OptionSetMemberLink optionSetLink = new OptionSetMemberLink();
		optionSetLink.setRoleAObject(); //input OptionSet.class
		optionSetLink.setRoleBObject(); //input ChoiceMaster.class
		wt.fc.PersistenceServerHelper.manager.insert(optionSetLink);//store in DB
		ChoiceMappableChoiceLink choiceLink = new ChoiceMappableChoiceLink();
		choiceLink.setRoleAObject(); //input ChoiceMappable.class which is WTPart, EPMDocument all objects in the system where the choices can be set
		choiceLink.setRoleObject(); //input ChoiceMaster.class
		wt.fc.PersistenceServerHelper.manager.insert(choiceLink);// store in DB
PetrH
