Jan 28, 2025 11:32 AM UTC
New Attribute creation under resulting objects of change task
Version: Windchill 12.1
Use Case: We are trying to create a new attribute "Models Affected" which is a Text box under resulting objects of change task. This should appear as a column under Resulting Objects. Users in this box can give the models affected after this change.
Description:
I am unable to follow the article - Create a Data Utility
Could you please help me in creating a new attribute which can store the text by sharing any procedures or tips & tricks?
HelesicPetr
Jan 28, 2025 12:24 PM UTC
Hi @NY_10657410
Why do you not able to create DU?
PetrH
Jan 29, 2025 6:03 AM UTC
Hi @HelesicPetr ,
I am able to follow 1 and 2 steps where as the 3rd step is bit ambiguous to follow.
HelesicPetr
Jan 29, 2025 6:23 AM UTC
Hi @NY_10657410
What steps do you talk about ?
Custom Table Views, Create MVC Builder Table
or
Extend the class and Override the method?
Here is very useful resource for DataUtility
CS360977 - [Knowledge Hub] Windchill PLM - Data Utility
PetrH
