May 25, 2017 11:07 AM UTC
Not able to open popup as small size
I have a table action. I am trying to open a popup window to show an UI page. But I would like to show that window to be small. Here is my action,  <moreurlinfo>height=500,width=560</moreurlinfo>  It is still opening default size page. Could you please help me to resolve this issue.
<action name="selectECO" multiselect="true" selectRequired="true">
           <command windowType="popup" url="netmarkets/jsp/pac/pacSelectChangeFromAgile.jsp?mode=ECO"/>
</action>
May 30, 2017 12:45 PM UTC
The sizing of the window is  done in the JS function popupActionMainImpl.
What you can do is use Chrome and its debugger, activated by the F12 key. ( should work with firefox too I think )
(1) in the URL, add &jsDebug=1 to use the uncompressed JS files. Easier to debug 🙂
(2) in the console, type debug(popupActionMainImpl);
This add a breakpoint at the begining of the popupActionMainImpl function.
And launch your action...
You can now go step by step in the function.
You can validate that moreInfo is set :
A little bit further in the function, you'll find the code that handles the window sizing.
As you can see, the code tries to find a size with a cookie mechanism, and next from the moreurl info.
This should help you to understand what's going on 🙂
May 31, 2017 4:59 AM UTC
Thanks Olivier for your response. Let me do the debug and try to fix the issue. When I asked the PTC support the same question the response is,
can't be possible to do window resize in customization.
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=13706368
Thanks.
May 31, 2017 12:59 PM UTC
This is odd, even if you create a custom popup window, I guess it is opened the same way as an ootb one.
If your action goes through popupActionMainImpl, moreurlinfo should be handled 🙂
good luck in your debug.
