Mar 2, 2017 9:07 AM UTC
Object reference attribute
I have created ObjectReference attribute for WTPart which refers to WTDocument (other Side class: wt.doc.WTDocument and otherside attribute : number), but in create part wizard this attribute shows as "unassignable". How to to display dropdown list of Document instances?
Mar 2, 2017 4:35 PM UTC
May I know how did you achieve this?
Mar 3, 2017 1:00 PM UTC
Hi Sarvanan,
You can follow below steps.
  • Create an IBA of String type in WTPart.
  • Use an custom data utility to create Document Picker or Dropdown list of existing document.
Kaushik
ShirishMorkhade
Mar 23, 2017 11:41 AM UTC
Hi Saravanan Kuppa Mohanram & Shashikantha Shankaracharya,
Just like @Kaushik said, you can create IBA and then hook data utility. I believe when says Data Utility, he is referring to SuggestTextBox.
I recently worked on SuggestTextBox. In this you will have to create a suggestion class (implementing Suggestable interface) which would basically do the query. This class should be registered as a service, This service could be called from suggestTextBox wrapper tag.
Something like this: datautility for a non single-value constraint attribute
In Windchill installation there are some example provided there at http://YOUR_WINDCHILL/Windchill/app/#ptc1/carambola/customization/examples/picker/suggest
I hope this helps you!
Shirish
Mar 29, 2017 7:59 AM UTC
If you want to create an association between WTDocument and WTPart, you may take a look at configurables links :
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS156972&art_lang=en&posno=1&q=configurable%20link&ProductFamily=Windchill%7CWPA&source=search
