OData Filter by Custom Attribute
Version: Windchill 12.1
Use Case: I am attempting to do an OData call to retrieve parts filtered by a custom attribute on a part. How do I do a GET request with a $filter that allows me to filter a custom attribute?
Description:
Attempted URL:
Error message:
 "error": {
 "code": null,
 "message": "The property 'MY_ITEM_NUMBER', used in a query expression, is not defined in type 'PTC.ProdMgmt.Part'."
URL's I've tried that do not work:
Error message:
 "error": {
 "code": null,
 "message": "The URI is malformed."
Other URLs:
I tried following the steps here without success: https://community.ptc.com/t5/Windchill/How-to-fetch-part-list-using-custom-attribute-via-Windchill/m-p/969188#M81973
Is this possible? Seems like it should be a common thing to do, but I haven't found much help online or in the KBs. Thanks for the help in advance!
Catalina
Community Manager
Hi @CB_12625553
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
Please map the property MY_ITEM_NUMBER in PartsExt.json file in the custom rest folder. You could be able to filter based on custom attribute. Refer Adding Custom Properties to Entities in PTC Domains.
PartsExt.json
"extends": "Part",
"attributes": [
"name": "MY_ITEM_NUMBER",
"internalName": "MY_ITEM_NUMBER",
"type": "String"
Post the above step you can apply filter like below
https://company.ptcmscloud.com/Windchill/oauth/servlet/odata/ProdMgmt/Parts?$filter=contains(MY_ITEM_NUMBER,  '12345')
6-Contributor
How to do same for subtype eg Part-->Wheel(Subtype)
Fadel
23-Emerald II
for subtype you should have endPoints OOTB LIKE BELOW
Buiꓘa
6-Contributor
have you tried this in subtype?
