Only show latest revision for serial numbers?
I have a tab that shows serial numbers and want to change the view such that it only shows the latest revision of each serial. For example, if I have serial 001 Rev A and then rev that part to Rev B, the list will show both 001 Rev A and Rev B, when I just want it to show Rev B. Is there any tips on how to achieve this?
Emeritus
February 19, 2024
Hi @Aaronm87!
Thank you for your question!
I am taking the liberty to bring your image to more visibility, to facilitate finding an answer on your post.
I hope you will find a solution with an experienced member soon.
HelesicPetr
Hi @Aaronm87
If you really search for a customization, the best way is to create own table where you show all instances based on own filter.
How to do so you need to know how to customize windchill and how to write a code.
PetrH
