May 18, 2018 9:56 AM UTC
Orgnization which is created by using API is not visible under Org tab
Hi All,
I have created WTOrganization by using Windchill API. it was successfully created.
When i tried to add Org admin to this newly created Organization found that this Organization is not present under Org Tab.
I have check WTORGANIZATION table in DB and found its entry.
How i can get this new organization under my Org Tab ?
Vivek
6-Contributor
May 23, 2018 7:58 PM UTC
Do you have the code available?
May 24, 2018 7:37 PM UTC
Hi Vivek,
This might not be helpful but when you clicked the Organizations tab did you then click "View All" to view the entire list? I believe that the objects shown in the tab by default are only those objects that you've accessed in the past. Since the Org is new you've never accessed it before so it might only be shown in the "View All" list right now.
