Part Numbering based on multiple attribute values
How to set a different number sequence based on multiple attribute values in Windchill PDMLink 11.2.1.0?
Example:
Attribute 1: A , B , C
Attribute 2: 1, 2, 3
Attribute 3: X, Y, Z
Combination will be like
A1X001
A1Y001
A1Z001
A2X001
A2Y001
A2Z001
vasanth1-VisitorAuthor
Sample schema should be like:
A1X001, A1X002, A1X003,......
A1Y001, A1Y002, A1Y003,......
A1Z001, A1Z002, A1Z003,......
A2X001, A2X002, A2X003,......
A2Y001, A2Y002, A2Z003,.....
A2Z001, A2Z002, A2Z003,.....
A better explanation of what you are trying to do with that numbering scheme would help.
What defines when to use a different sequence?
Are you using auto-numbering?  There is an issue with that, it causes numbers to be skipped in certain instances.
It is a requirement from client.
Different schema based on the combination(or concatenation) of 3 attributes together.
3 digit autonumbering at the end of the combination.
No numbers to be skipped.
