Mar 11, 2016 10:26 AM UTC
Possibilty of exclude files by extensions and/or by size when they are uploaded to a WT_Document in Windchill
Windchill should exclude some files to upload in a WT_Document.
The filter should be by extensión (.odt, .exe, .....) or by size (for example only upload files minus than 500 MB.
These filters should be configurated by preferences.
18-Opal
Mar 11, 2016 3:21 PM UTC
Definitely doable.
A way to do something like this is with a listener.
You write and registers a listener to listen for the specific event.  Probably need to listen for both POST_STORE and POST_MODIFY event as you'd probably want to check this condition for both new WTDocs and exisiting WTDocs.
There might also be an UPLOAD event that would work as well.  I'd have to investigate to see if such an event exists and if it if fired during upload to WTDocs.
When the event occurs your custom code runs.  Your code checks the extension and files size.
If either are not valid throw an Exception.
The user would be notified immediately of the problem and could not check in the WTDoc until the upload was validated.
You do need to know some Java to do this but it is very doable.  I've done stuff like this in the past to check attributes where OOTB constraints could not get the job done.
18-Opal
Mar 11, 2016 3:52 PM UTC
Jose,
I recalled I had done something like this for a customer. The customer wanted to limit WTDoc attachments file types.
The events I keyed off were POST_STORE and POST_MODIFY.
Apr 22, 2024 7:45 AM UTC
I find it pretty amazing that in the growing amount of security issues during the years when these kind of questions started, this has not been added.. Basing development on "amount of votes for an idea" doesn't cut it here. There's plenty of logical reasons to allow checks of some sort (extension, MIME type, etc.) for uploads without extensive coding done by every customer.
https://www.ptc.com/en/support/article/CS54468
https://www.ptc.com/en/support/article/CS356834
https://community.ptc.com/t5/Windchill-Ideas/Prevent-upload-of-possibly-dangerous-file-types-to-Windchill/idi-p/456860
https://www.ptc.com/en/support/article/CS401738
HelesicPetr
Apr 22, 2024 7:59 AM UTC
Hi @Zoltán
Yes your right it is interesting. but the idea has been archived = no plan to implement.
There were low votes and no one cared about this idea to recreate it and support the voting.
Trust me the risk is pretty low that some paid user with their password would upload a dangerous file to the system.
It is their responsibility to keep a system safe on daily manner.
PetrH.
Apr 22, 2024 9:42 AM UTC
I agree that users should be trusted to comply with certain standards, behaviours, etc. and that liberal access to system for example is good, but I see companies wanting to narrow down risks, so this feature is probably interesting for far more than can be collected from a vote on an idea.
Well, we'll see what the future brings. 🙂
tarik_perc
May 18, 2024 11:34 PM UTC
Windchill does not filter any extension for wtdocument because they could come from any authoring applications
There is an example of scan files in the help center, see https://www.ptc.com/en/support/article/CS361825
You can create custom preferences and check their runtime or user values from within the code.
I believe you will also deal with Apache config for large file size
