Post Select Validation Logic for Custom Action - Remove Objects
Hello All,
I have a requirement to add a custom action which will remove Objects in resulting Items table on
wt.workflow.work.WorkItem -> Resulting Objects Table
I need help on how to apply Post Select Validation Logic to remove only required Object type from the Selected Objects in the Table?
HelesicPetr
Hi @Rohaan
Do you remove the objects from wizard table or review detail page?
if it is regular table in detail page you can use preProcess method to check if the correct types are selected.
public FormResult preProcess(NmCommandBean nmCommandBean, List<ObjectBean> list) throws WTException
PetrH
HelesicPetr
Hi @Rohaan
PetrH
