11-Garnet
Mar 22, 2023 1:47 PM UTC
Problem getting CSRF_NONCE value (HTTP 400)
I am stuck and need suggestions what to do. I am trying to get CSRF_NONCE value, using rest query with java api (I working with Windchill 12.0 server). But what ever I do I get HTTP code 400.
Tried queries were: https://myServer/Windchill/servlet/odata/PTC/GetCSRFToken()
My code is:
URL url = new URL ("https://myServer/Windchill/servlet/odata/PTC/GetCSRFToken()");
HttpURLConnection conn = (HttpURLConnection) obj.openConnection();
conn.setRequestMethod("GET");
conn.setRequestProperty("Content-Type", "application/json");
conn.setRequestProperty("Authorization", "Basic " + authString); //authstring is Base64 encoded
conn.connect();
BufferedReader in = new BufferedReader(new InputStreamReader(conn.getInputStream()));
String inputLine;
StringBuffer response = new StringBuffer();
while ((inputLine = in.readLine()) != null) {
 response.append(inputLine);
in.close();
conn.disconnect();
I am pretty sure that code is ok because if I try query "https://myServer/Windchill//servlet/rest/objects?$select=number&typeId=wt.part.WTPart"
I am getting right result. Also both queries return right result if I use Firefox or Postman instead of my
code.
If anybody have suggestions what is wrong or what to do I will be grateful for help.
Best reagads,
Nenad
HelesicPetr
Mar 22, 2023 3:25 PM UTC
Hi @nbojcetic
You forgot to add a accept property string
conn.setRequestProperty("accept", "application/json");
I test it and it works
PetrH
HelesicPetr
Mar 22, 2023 2:01 PM UTC
Hi @nbojcetic
May be the version does miss in the url
https://wchserver.aa.com:443/Windchill/servlet/odata/v3/PTC/GetCSRFToken()
 PetrH
nbojcetic11-GarnetAuthor
11-Garnet
Mar 22, 2023 2:12 PM UTC
PetrH,
thank you for the suggestion, I already tired that but with the same result.
Thanks!
HelesicPetr
Mar 22, 2023 2:24 PM UTC
Hi @nbojcetic
Have you tried earlier versions? v1 ? v2?
go to the a restApi documentation and test it directly from the windchill if it works.
https://wch.server.com/Windchill/netmarkets/html/wrs/doc.html
PetrH
HelesicPetr
Hi @nbojcetic
PetrH
11-Garnet
Mar 22, 2023 3:56 PM UTC
YES, that is correct and now it works. Thank you very much! 😊
Nenad
