Product Management - getPartStructure API
In Windchill Rest Services Product Management>getPartStructure
I used $expand = Components($expand=Part,PartUse;$levels=max)  API , It executed for 4 mins. To reduce execution time, i want to provide 3 field names in $select query. Kindly refer the attached JSON document to form the query to fetch the field 'PartNumber, ComXXXEngineeringSequences, ItemTypeComXXXIndustriesItemType'.
I able to fetch two fields using query
$expand = Components($expand=PartUse($select=ComXXXEngineeringSequences))
But when I tried to fetch ItemTypeComXXXIndustriesItemType using query $expand=  Components($expand=Part($select=ItemTypeComPolarisindPolarisIndustriesItemType);$levels=max)
It throwed error  [ - The property 'ItemTypeComXXXItemType', used in a query expression, is not defined in type 'Part'.]
Kindly check the attached file and let me know how to fetch 'PartNumber, ComXXXEngineeringSequences, ItemTypeComXXXIndustriesItemType' together.
HelesicPetr
Hi @AP_10343008
If you use wt.part.WTPart as a type does it work?
try to use a full path definition type "wt.part.WTPart|ItemTypeComPolarisindPolarisIndustriesItemType"
PetrH
I tried the query Components($expand=Part($select=wt.part.WTPart|ItemTypeComPolarisindPolarisIndustriesItemType))
It throwed error  [ - The part 'wt.part.WTPart' is not defined.]
HelesicPetr
@AP_10343008
You need to find how the type should be exactly defined 😄
PetrH
