Dec 13, 2016 3:24 PM UTC
Provide Sequence to the Change Task by Customization?
Hello All,
I am looking for a way to provide the sequence to the Change Task through customization from the CN workflow. Is there any supported API which can be used to accomplish this?
Karan
Sep 26, 2018 2:32 PM UTC
WTChangeActivity2 task;
WTChangeOrder2 changeNotice;
String sequenceNumber = (String) wt.change2.changeplanning.ChangePlanningHelper.getService().getExecutionValues(changeNotice).get(task);
 This will give you the sequence number of a given task and a given change notice.
I haven't figured out though how to modify those values. I can just read them and use the information in my workflow.
Feb 10, 2025 2:04 PM UTC
the below api can be used to create plan :
wt.change2.changeplanning.ChangePlanningHelper.getService().createPlan(VersionableChangeItem arg0, Map<String, WTCollection> arg1)
