Publish Rules for AutoCAD
Hi All,
After various troubleshooting we were able to configure Custom AutoCAD worker to generate pdf.
Now we are trying to create publish rules to stop publishing on check-in.
It should only generate on specific state and manual creation of representation.
Attached is the script we tried however it not working.
Added AUTOCAD to publish.usesPublishRules in wvs.properties.
Any suggestions would be appreciated.
Thanks.
DKWcAnswer
Found the solution publishing rules working fine for AutoCAD.
HelesicPetr
Hi @DKWc
You need to set wvs property to use publish rules for AUTOCAD
the property is: publish.usesPublishRules
default is ARBORTEXT and GALAXY so AUTOCAD is missing in that property.
https://www.ptc.com/en/support/article/CS111916
PetrH
DKWc15-MoonstoneAuthor
Hi Petr,
Made the changes in wvs properties and then applied rules.
Unfortunately no go.
HelesicPetr
Hi @DKWc
The point is if the AUTOCAD is supported to use the publish rules.
I've checked help, and can not find autocad as a option - authoring aplication.
check this> WVS Publish Rules Enable
try to use all options.
Or contact PTC support to get correct option if it exists.
PetrH
