Publishing customization
Version: Windchill 11.1
Use Case: Set publishing priority based on naming conventions
Description:
Hi Everyone,
I've a use case where I need to filter the files with naming conventions (Eg: mnpl) need to be published on high priority.
Here I need customization which need to be added in Windchill properties and sample code to get this achieved.
Thanks in advance,
Keerthi
Catalina
Community Manager
Hi @Keerthivarman
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
Catalina | PTC Community Manager
avillanueva
23-Emerald II
This article points to an example code that you can start with:
https://www.ptc.com/en/support/article/CS132318
