Feb 5, 2025 10:17 AM UTC
Query-Links thrown NullPointerException for more than one value to object_ref parameter
Query-Links webject thrown NullPointerException
This exception thrown when 2 or more id send to object_ref
Exception thrown for following inputs to Query-Links:
TYPE|DIRECTION|output_type|auto_navigate|attribute
wt.part.MasterIteration|master|FULL|false|iteration,number,masterReference
wt.part.WTPartDescribeLink|describesDoc|FULL|true|describes,name,number,masterReference
wt.part.WTPartReferenceLink|referencesDoc|FULL|true|referencedBy,name,number,masterReference
Windchill: 12, 13
Exception:
Nested exception is: java.lang.NullPointerException
at com.ptc.core.adapter.server.impl.AbstractWebject.addTypeInstance(AbstractWebject.java:925)
at com.ptc.core.adapter.server.impl.AbstractWebject.addTypeInstance(AbstractWebject.java:901)
at com.ptc.core.adapter.server.impl.QueryLinksWebjectDelegate.invoke(QueryLinksWebjectDelegate.java:497)
at com.ptc.core.adapter.server.impl.WebjectDelegateFactory.invokeDelegate(WebjectDelegateFactory.java:434)
at jdk.internal.reflect.GeneratedMethodAccessor1027.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at wt.method.WTAdapterImpl.processWebject(WTAdapterImpl.java:840)
at wt.method.WTAdapterImpl.processRequest(WTAdapterImpl.java:537)
at com.infoengine.procunit.adapter.Adapter.send(Adapter.java:199)
at com.infoengine.SAK.ObjectWebject.invoke(ObjectWebject.java:319)
Webject:
<ie:webject name="Query-Links" type="OBJ">
<ie:param name="INSTANCE" data="<%=com.infoengine.au.NamingService.getVMName()%>" valueSeparator=";" delim=";" />
<ie:param name="TYPE" data="wt.part.MasterIteration"/>
<ie:param name="object_ref" data="VR:wt.part.WTPart:4655178:591698760-1730379217407-1158614409-186-30-168-192@vinw16wc30186.eqvm.local#VR:wt.part.WTPart:4655819:591698760-1730379217407-1158614409-186-30-168-192@vinw16wc30186.eqvm.local" valueSeparator="#" delim="#"/>
<ie:param name="DIRECTION" data="master"/>
<ie:param name="output_type" data="FULL"/>
<ie:param name="auto_navigate" data="false"/>
<ie:param name="attribute" data="iteration,number,masterReference" delim=","/>
<ie:param name="group_out" data="objects"/>
</ie:webject>
at wt.adapter.query.QueryLinksWebjectDelegate.navigate(QueryLinksWebjectDelegate.java:549)
at wt.adapter.query.QueryLinksWebjectDelegate.navigate(QueryLinksWebjectDelegate.java:465)
at com.ptc.core.adapter.server.impl.QueryLinksWebjectDelegate.invoke(QueryLinksWebjectDelegate.java:265)
at jdk.internal.reflect.GeneratedMethodAccessor307.invoke(Unknown Source)
<ie:param name="TYPE" data="wt.part.WTPartDescribeLink"/>
<ie:param name="object_ref" data="VR:wt.part.WTPart:4751222:591698760-1730379217407-1158614409-186-30-168-192@vinw16wc30186.eqvm.local" valueSeparator="#" delim="#"/>
<ie:param name="DIRECTION" data="describesDoc"/>
<ie:param name="auto_navigate" data="true"/>
<ie:param name="attribute" data="describes,name,number,masterReference" delim=","/>
</ie:webject>
rhartAnswer
Feb 11, 2025 4:13 PM UTC
The direction should be either describes or describedBy
e.g. link from the part to doc
(the part is described by the doc)
	<ie:param name="instance" data="<%= wtadapterVMName %>" valueSeparator=";" delim=";" default="Windchill" />
	<ie:param name="object_ref" data="VR:wt.part.WTPart:605752690"/>
	<ie:param name="DIRECTION" data="describedBy"/>
</ie:webject>
 e.g. link from the doc to the part
(the doc describes the part)
	<ie:param name="object_ref" data="VR:wt.doc.WTDocument:1249683439"/>
	<ie:param name="DIRECTION" data="describes"/>
</ie:webject>
Catalina
Community Manager
Feb 11, 2025 1:34 PM UTC
Hi @AD_10574558
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
rhart16-PearlAnswer
</ie:webject>
</ie:webject>
Feb 12, 2025 5:26 AM UTC
Hello @rhart, Thank you very much for the response!
 Similar to "DescribeBy" attribute, "DescribeDoc" reference attribute also shown in logical attribute report, that's why I used it to fetch document form part
Not sure why Windchill is still showing it, as it looks like it is deprecated or not working for direction parameter. If I missed anything or any understanding please let me know.
Can you please also let me know why wt.part.MasterIteration is not working?
