18-Opal
Nov 22, 2017 12:58 AM UTC
Query to get all the available object types within a selected context in Windchill
Good morning I'm SeonHo
There are some questions about configuring the Promotion Request Approval Process.
We have configured as follows.
wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
wt.fc.QueryResult qr= wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
while (qr.hasMoreElements())
 wt.doc.WTDocument doc=(wt.doc.WTDocument) qr.nextElement();
 wt.lifecycle.LifeCycleServerHelper.service.setState((wt.lifecycle.LifeCycleManaged)doc,wt.lifecycle.State.toState("DESIGNCHANGE"));
try
wt.util.WTProperties props = wt.util.WTProperties.getLocalProperties();
VERBOSE = props.getProperty("wt.maturity.verbose",VERBOSE);
catch( Throwable t )
try{
 wt.maturity.MaturityServerHelper.service.unlockTargets (pn);
} catch (wt.maturity.MaturityException me){
 if ( VERBOSE )
 me.printStackTrace();
As a result, when I rejected it, I succeeded in designing the life cycle by design change.
But it was the case of WTDocument.
For WTParts, an error has occurred.
Spoiler
wt.util.WTException: java.lang.ClassCastException: wt.part.WTPart can not be cast to wt.doc.WTDocument
Nested exception: java.lang.ClassCastException: wt.part.WTPart can not be cast to wt.doc.WTDocument
Nested exception: wt.util.WTException: java.lang.ClassCastException: wt.part.WTPart can not be cast to wt.doc.WTDocument
wt.workflow.engine.FailedExpressionException: wt.util.WTException: java.lang.ClassCastException: wt.part.WTPart can not be cast to wt.doc.WTDocument
So I modified the code as follows.
try
}catch(wt.util.WTException e){
		wt.part.WTPart pt=(wt.part.WTPart) qr.nextElement();
 wt.lifecycle.LifeCycleServerHelper.service.setState((wt.lifecycle.LifeCycleManaged)pt,wt.lifecycle.State.toState("DESIGNCHANGE"));
try
try{
 if ( VERBOSE )
 However, I have also encountered the same error.
In my opinion, i can figure out the type of WTObject and then use switch to specify a specific lifecycle as in the first case for WTDocument.
After that, we follow the origin process for the remainder and return to the state before the promotion.
The code will look roughly like this:
		wt.object.type ot = qr.getObjectType ???
 switch(ot)
 case "WTDocument" : wt.doc.WTDocument doc=(wt.doc.WTDocument) qr.nextElement();
wt.lifecycle.LifeCycleServerHelper.service.setState((wt.lifecycle.LifeCycleManaged)doc,wt.lifecycle.State.toState("DESIGNCHANGE")); break;
 default : break;
Is it wrong?
I would appreciate your feedback.
thank
Nov 22, 2017 8:20 AM UTC
Remember, Windchill's model is object oriented 🙂
Each business object implements interfaces, each interface implements a behavior.
In your case,
wt.ifecycle.LifeCycleManaged
And the service methods signature is
LifeCycleManaged setState(LifeCycleManaged var1, State var2) throws WTException, LifeCycleException;
Therefore, you can use :
wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice) primaryBusinessObject;
wt.fc.QueryResult qr = wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
while (qr.hasMoreElements()) {
 wt.lifecycle.LifeCycleManaged lifeCycleManaged = (wt.lifecycle.LifeCycleManaged) qr.nextElement();
 wt.lifecycle.LifeCycleServerHelper.service.setState(lifeCycleManaged, wt.lifecycle.State.toState("DESIGNCHANGE"));
try {
 VERBOSE = props.getProperty("wt.maturity.verbose", VERBOSE);
catch (Throwable t) {
try {
 wt.maturity.MaturityServerHelper.service.unlockTargets(pn);
} catch (wt.maturity.MaturityException me) {
 if (VERBOSE)
This code works for all lifeCycle managed objects
In your case,
try {
try {
 if (VERBOSE)
CHASEONHO18-OpalAuthor
18-Opal
Nov 23, 2017 12:15 AM UTC
thanks @olivierfresse!!
problem has been solved by you.
I would like to learn more about writing code in windchill
How do you write code about the API ...
Can I get tips on writing windchill code please?
In addition, what api should I use to determine if an object's type is a WT document or an EPM document?
wt.fc.WTObject ot = pn wt.fc.WTObject.getDisplayType()
Was the correct way to write code using getDisplayType ()?
Nov 23, 2017 8:27 AM UTC
Well, first the easy one.
Windchill Objects are java objects, therefore you can get their class name..
WTPart foo = .... // initialized somewhere
String className = foo.getClass().getName();
// -> className contains "wt.part.WTPart"
This is pure java.
But PDMLinks provide softtypes... So if you need the logical identifier, you have to use
import wt.type.TypedUtilityServiceHelper
WTPart subTypedPart = ... // retrieved from somewhere
String subType = TypedUtilityServiceHelper.service.getExternalTypeIdentifier(subTypedPart);
// returns WCTYPE|wt.part.WTPart|project.TaskSkillResource
In the example, my subTypedPart is a subtype of WTPart and has a logical id project.TaskSkillResource.
Next, learning PDMLinks api, well, it's a huge task 🙂
But there is quite a lot of documentation : https://support.ptc.com/appserver/cs/doc/refdoc.jsp
and you can find lots of code sample in PTC  support site.
