Recompiling DLL libraries on WGM failed with an exception.
We have a custom dll code which was working on previous version on WGM but post updating WGM it failed to compile. Need to know how to resolve compilation issues. Do we need to rebuilt toolkit libraries or there is another way to achieve this?
    avillanueva
    23-Emerald II
    Can you detail the exception or what this is? Short answer is yes, if its failing to compile, then likely one of the dependencies you relied on has changed.
