18-Opal
Reload WRS files without restarting Method Server?
Version: Windchill 13.0
Use Case: Updating a custom WRS domain.
Description:
Hello All,
I need to do quite a lot of trial-and-error on my custom WRS domain, mainly manipulating .js files. Restarting MS every time to pick up my changes is annoying.
Since those scripts are interpreted by Nashorn anyway, I thought... maybe there's some magic trick (e.g. calling some MBean method) to reload them without restarting MS every time?
Thanks!
Catalina
Community Manager
Hi @Constantine
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
18-Opal
At the end of the day I didn't find a good solution, so I fired up my Java debugger and moved the code from JS files into Java classes instead. This way I can do trial and error on my OData endpoints without restarting the server thanks to JVM code hot swapping. The latter has its own limitations, but it takes away 90% of the pain associated with restarting the MS.
Hi @Constantine
Its great to know what you have found some approach . I am interested to know  how did you achieved it in the java classes . can  you please elaborate about this JVM code hot swapping approach
