May 28, 2024 12:17 PM UTC
Remove/Hide the attribute based on the value of other attribute while Creating WTPart & EditPart?
Version: Windchill 11.1
Use Case: Is It remove/hide the attribute based on the value of other attribute while Creating WTPart and Editing WTPart?
Description:
AndrewK
Community Manager
May 28, 2024 3:55 PM UTC
Thank you for your question.
I’d like to recommend bringing more details and context to your initial inquiry. It also helps to have screenshots to better understand what you are trying to do in your process. This will increase your chances to receive meaningful help from other Community members.
tarik_perc
Jul 27, 2024 12:11 AM UTC
@SP_10298892  That’s possible via cascading rules on type and attribute management, no customization.
2 Bonus
Some attributes can be hidden via Standard Profile, if so they will be hidden in all contexts, this is not your use case.
We can also hide them via custom validator(java class), also not your use case.
