7-Bedrock
Remove Organization Name Info
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.9
How remove the Organization Name in the Windchill notifications?
I follow the steps of CS312309 but not working
    Catalina
    Community Manager
    Hi @dmazaira
    Thank you for your question.
    It appears your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
    Best regards,
    Catalina | PTC Community Manager
    avillanueva
    23-Emerald II
    Can you show or explain what you tried so far? Please post your email template and the result you are getting.
    dmazaira7-BedrockAuthor
    7-Bedrock
    templateMail.jpg The Blue rectangle information it's that I want remove. I modify the NotificationRobot template, but only Apply in new Workflow Template.  It does not work, even if you iterate the workflow Template.  It's not working in the actual workflows process that are running and the new Workflow Process with a workflow Template created before the change..
    avillanueva
    23-Emerald II
    I've done some email modifications but I did not remove that part. I think its added to the template somewhere else.
