When using the Windchill REST API, I am limited to receiving only 25 records by default due to the stiptoken=25 parameter. However, I want to retrieve all the data, so how can I remove the stiptoken parameter via the API? Can you assist me with this?
Max number of results for each response limited to 2000. You would have to parse the response and check if it has "@odata.nextLink" if so retrieve the next url and so on.
Windchill Satisfaction Survey
Help shape the future of Windchill. Take our 5-minute survey and share your feedback.
