6-Contributor
Rename CADDocuments and Parts with odata Endpoint
Version: Windchill 12.1
Use Case: I would like to change Number, Name, and File Name attributes for many CADDocuments and Parts. It took to much time to change the attributes manually. So I would like to use an odata Endpoint.
Description:
But i did not find any Endpoint in the odata documentation that fits my needs.  Do you have any ideas how to solve this Problem?
HelesicPetr
Hi @DK_9661096 \
Yes, you can write own endpoint and develop customization to achieve your needs.
Also it can be easier to write a custom utility that reads some input file to change the numbers.
PetrH
HelesicPetr
Hi @DK_9661096 \
PetrH
I would really appreciate your help with renaming CADDocuments by developing and deploying my own customization using OData. Could you please guide me through the proper tutorials or procedures to achieve this?
Your guidance and support would be greatly appreciated.
Thank you,
Aundy
HelesicPetr
Hi @Sankarakumar
Everything is described in the RestApiu documentation
Windchill REST Services User's Guide
PetrH
Fadel
23-Emerald II
Buiꓘa
HelesicPetr
Yes, you can use this API but you have to know the ID of the object.
Here is a option how to search the ID by number for an EPMDocument ...
How to get EPMDocuments in Windchill REST Services
PetrH
