Jun 9, 2017 9:07 AM UTC
Restrict going back to previous step : wizard
I have a wizard page with 2 steps. Once the user completes step1 and moves to step2, I would like to restrict the user going back to step1 again. Please help me if there is any way to implement this?
Thanks in advance.
20-Turquoise
Jun 9, 2017 4:59 PM UTC
You could use something like the following javascript functions:
findButtonByActionID("<action id of button>");
var buttonToDisable = findButtonByActionID("PJL_wizard_previous");
buttonToDisable.disable();
Some common action id's of buttons:
PJL_wizard_apply
PJL_wizard_next
PJL_wizard_ok
PJL_wizard_previous
These can be found in codebase/config/actions/actions.xml and other files in the same directory.
Another possibility would be to configure step 2 with custom buttons and not have a back or previous button. Also see the following 2 articles:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS237700
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS21969
