Retrieve Assembly Structure
Hello everyone,
 I need to wite a java custom class that retrieve the structure of an assembly (.asm) file.
The class must be execute in a listener after the CheckIn event.
I have found a call to Swagger REST Api (structure/objects descendants) and it is working on a standalone java class.
I wondering if it is possible to call a REST Api inside a java custom class executed at the CheckIn event.
If it is not possible what JAVA API I shoul use for a Windchill 11.0 M030 ?
Thankyou
ShirishMorkhade
Hi @gfontana,
If you could share/let us know how did you call Swagger REST Api (structure/objects descendants) from within standalone java class (your standalone example may be), I can play around it to see if we can call it inside check in event listner.
Shirish
gfontana1-VisitorAuthor
Hi Shirish,  the REST api call is:
http://<server>:<port>/Windchill/servlet/rest/structure/objects/VR%3Awt.epm.EPMDocument%3A696618/descendantSummaries?criteria=%7B%20%22levels%22%20%3A%201%20%7D
where <server> and<port> are valorized with the client data.
The java files is in attached
Note: the java class is in progress so probabilly there are some imprecision
Thank you
@gfontana
Try this OData REST API
POST <windchill_server>:<port>/Windchillservlet/odata/ProdMgmt/Parts('part_id')/PTC.ProdMgmt.GetBOM?$expand=Components($expand=Part($select=Name,Number),PartUse,Occurrences)
CSRF_NONCE: <nonce_value>
Content-Type: application/json
Request Body:
Thanks for your response.
I also would know the timeline of the swagger REST APi
yes thankyou
