Jun 25, 2021 3:14 PM UTC
Retrieve report template with OData
Hi all,
I need to retrieve template reports via the OData API. I have used the following API
/Windchill/servlet/odata/IE/InvokeIETask
 "Task": "com/ptc/windchill/enterprise/report/ExecuteReportTemplate.xml",
 "Params": [
 "Name": "object_ref",
 "Value": "wt.query.template.ReportTemplate:1234"
now i need to change the report criteria directly from the API. i tried to add a parameter but it doesn't seem to work. where can i find documentation? what is the correct parameter to pass?
I have this criteria
((Associated Part.Latest Iteration equals 1) AND (Part Master.Number in 1234))
mmancin1-VisitorAuthor
Jul 7, 2021 12:36 PM UTC
Any suggestions?
7-Bedrock
Apr 16, 2024 2:26 PM UTC
Hi @mmancin,
check this PTC article CS378132
