Mar 8, 2018 8:26 PM UTC
Rule XML file Import (File Attached)
Has anyone configured the rules.xml file when importing Libraries from one system to another (10.1->11.0) using the Import utility? Attached is the file I need to configure, I just need to know if attribute part errors I'm receiving when attempting to Import a Library is what ONLY needs to be configured in the rules.xml file?
