Aug 18, 2023 6:08 AM UTC
Running a custom class file from windchill shell (SSO) getting "wt.method.AuthenticationException"
I am getting following error while running a custom class file as described in CS353022. Windchill is configured with SSO + OpenDJ.
What could be the possible issue?  .. Could CS294361 be causing it?
Custom class has following for auth and invoking a method within class, error is coming at invoke.
RemoteMethodServer rms = RemoteMethodServer.getDefault();
rms.setUserName("wcadmin");
rms.setPassword("wcadmin");
rms.invoke("Login1","ext.participant.Login",null,null,null);
Running windchill wt.auth.Authentication also returns error
wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
        at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:918)
        at ext.siemens.pvp.Login.main(Login.java:36)
HelesicPetr
Aug 18, 2023 6:52 AM UTC
Hi @ND_102012
the issue is the SSO, method from windchill shell can not Authenticate .
you need set that http server do not use the SSO for that function from the windchill shell
someone else can have a solution.
I would recommend an another method to run then windchill shell
 try this method to run from a browser url address
package cz.custom.HELTest1;
public class Test1 implements RemoteAccess
		// http link to run this function
		// http://server.com/Windchill/servlet/WindchillAuthGW/cz.custom.HELTest1.Test1/runOwnMethod
	public static void runOwnMethod(HTTPRequest req, HTTPResponse resp) throws WTException, PropertyVetoException, IOException
	//... your code
PetrH
HelesicPetr
Hi @ND_102012
	//... your code
PetrH
Aug 18, 2023 7:33 AM UTC
You need to add an extra parameter
windchill --javaargs=-Dwt.auth.trustedAuth.username=<username> <package.java_class_name> <param1> <param2>...
 See also:
https://www.ptc.com/en/support/article/CS353022
HelesicPetr
Aug 18, 2023 7:46 AM UTC
Hi @BjoernRueegg
Oh this is the SSO login bypass 😄 good to know 😄
PetrH
