6-Contributor
Search Component Data Builder customization
Version: Windchill 12.0
Use Case: Performing Global Search on "Name & Number" only behavior, without Index Search when users select a check box added next to global search Field
Description:
Hello PTC Community !
I'm looking for a way to implement the use case requested by my client on Windchill 12.0.2.7 and Windchill 13.0.2.6 (upgrade in progress).
At first I proposed to automatically set following user's preferences values when he checks the box:
  • Enable Index Search to "No"
    /com/ptc/windchill/enterprise/search/includeIndexGlobalSearch
  • Keyword Search Behavior to "Name & Number" (3)
    /com/ptc/windchill/enterprise/search/controlKeywordSearchBehaviour
But this solution implies to save previous users's values to reset them whhile unchecking the box and the client wants that we study a way to implement the use case without impacting those preferences.
So, I tried to override the ootb DATA_ONLY component builder: com.ptc.windchill.enterprise.search.mvc.builders.SearchDataBuilder with following class added in codebase/config/mvc/custom.xml as we do for some other MVC Component Builders customizations.
Please find below an abstract of the code:
package com.client.search.builders;
import com.ptc.mvc.components.OverrideComponentBuilder;
import com.ptc.windchill.enterprise.search.mvc.builders.SearchDataBuilder;
@OverrideComponentBuilder
public class ClientSearchDataBuilder extends SearchDataBuilder {
But once deployed, I've this error raised in MethodServer:
org.springframework.beans.factory.NoUniqueBeanDefinitionException: No qualifying bean of type 'com.ptc.windchill.enterprise.search.mvc.builders.SearchDataBuilder' available: expected single matching bean but found 2: com.ptc.windchill.enterprise.search.mvc.builders.SearchDataBuilder#0,com.client.search.builders.ClientSearchDataBuilder#0
I tried many things in addition to make Spring configuration working, but it's still running like if @OverrideComponentBuilder annotation was not taken into account here.
FYI, OOTB SearchDataBuilder is defined like this:
@ComponentBuilder(value = {"search.default.searchResults"}, type = ComponentBuilderType.DATA_ONLY)
public class SearchDataBuilder extends AbstractJcaDataSourceComponentDataBuilder
 Thanks in advance for your help/advices/other solutions...
Julien
HelesicPetr
Hello @JulienBlais
Have you changed a mvc Search-configs.xml configuration ? ("\Windchill\codebase\config\mvc\Search-configs.xml")
I guess that there is still the original class and there should be yours new one.
Try to update the xml file configuration and will see if it helps
PetrH
HelesicPetr
Hello @JulienBlais
PetrH
6-Contributor
Hello @HelesicPetr,
Thanks for pointing out this config file !
I updated the class name to reference mine, AND removed definition of my class in custom.xml one and it worked !
For me that was feasible without modifying ootb configuration files, but only custom.xml one. Do you know why it's specific here and don't you think I could do some configuration working only using the custom.xml file ?
Thanks !
HelesicPetr
Hi @JulienBlais
I understand but I just think that the original configuration is not overwritten by the custom.xml file in this case and that is a reason of the error.
Why? who knows 😄
PetrH
This should be an OOTB functionality and should not be a customization.  But sadly we have to do as a customization
HelesicPetr
@plmcore
That happens all the time 😄
PetrH
