Search result table
Hello everyone,
 I know that IBA attributes are only visible in result table if: I select only one type or I added a criteria on an attributes (but the only attribute visible is those used in criteria)
This is not enough for my client (he has Windchill 11.0), he wants all attributes always displaied as result of the search; so i wondering if:
I have to create a custom action on the search result table ?
In Windchill 11.2 there will be this possibility ?
Thank you
Giorgio Fontana
joe_morton
All attributes?
You can modify the search results view to add additional columns and save that as the default for all users. But the columns you can add are limited by what you searched for. I don't believe you can show all attributes for all types. But I believe you could, for example, make a WTPart view that shows all WTPart attributes when you search for a WTPart.
gfontana1-VisitorAuthor
Hi Joe,
I'll try your idea and let you know the results
Thank you
