select for update by QuerySpec
Hi all,
I want to know how to realize the function with QuerySpec or other measure same as SQL statement of "select for update".
I found "qs.setLock(true)" api, but according to TS it is unsupported api.
backgound:
Target class is created with Information Modeler to manage specific list of numbers. Stored numbers on the database table need to be exclusively used with WTPart each by each. So I want to update the column which means processed flag when a record is used. I think a record should be locked when it is extracted first.
good question!
Try this method:
com.ptc.core.percol.PersistedCollectionServerUtils.rowLockCollections(final WTSet holdersOrCollections)
shin1h13-AquamarineAuthor
Hi fivigg,
Thank you for your reply.
Although I checked that method, it is package-private method.
Can I use it somehow?
I found below methods which are possible to be solution.
I still need to identify how would the exception ocurr if a row had been locked, though..
PersistenceHelper.manager.refresh(ObjectIdentifier objId, boolean lock)
or
PersistenceHelper.manager.refresh(Persistable obj, boolean fullRefresh, boolean inPlace, boolean lock)
