Sequence CN with subsequent CN's
Hello Everyone,
Looking for some direction. Current company is using engineering CR to CN with Change Tasks (sequenced) with a downstream manufacturing CN (mCN). The task to create the mCN is within the template of the engineering Change Notice tasks.
Question. Is there a way to systematically sequence CN’s?
Assume we can have a CT template to create another CN. A task could be created in the CN workflow to create the downstream CN’s. But the sequence of then the CN’s move forward is missing with those options.
lgrant16-PearlAuthor
Currently, the company uses the CN workflow to have the user create the first set of CT’s, once those are completed the workflow sets the resulting objects to the Target State. The workflow then sends another task to create more CT’s in what they call “post release”, again once completed the workflow sets the resulting objects to the Target state. They can daisy chain along like this more, but each set would be completed before the next set could be created. Objects from the CR would need to be moved to the CT’s as they are created.
I don’t see anyone taking a stab at this, probably because this is basic OOB feature of CIB who would manage implementation of the change.
