3-Newcomer
Apr 15, 2025 2:04 PM UTC
Set Date Attribute to (Assigned Date + 5 Days) Using Workflow Transition Code in Windchill
I need to get the Assigned Date from My Task once the activity is started. Using the self variable, I can retrieve the WFAssignment object that contains all task details. From this, I want to take the Assigned Date, add 5 days to it, and then set that new date to a date attribute using IBA.
Can anyone help me with example code that should be written in the Transition tab of the workflow for this?
18-Opal
Apr 17, 2025 4:39 PM UTC
Very doable.
I’ve done similar for a company that wanted to reset due dates on tasks.
And for companies that wanted to send an alert 5 days before something was due.
Custom code for sure but it is doable.
3-Newcomer
Apr 17, 2025 4:47 PM UTC
Can you please share the example code it will be helpful to implement it in the workflow
avillanueva
23-Emerald II
Apr 17, 2025 5:27 PM UTC
Here is something I did that validated need by date on change request in workflow:
java.util.Calendar c=java.util.Calendar.getInstance();
c.add(java.util.Calendar.DATE,21);
java.util.Date n=((wt.change2.WTChangeRequest2)primaryBusinessObject).getNeedDate();
if(n == null)
result="null";
else if (c.getTimeInMillis() < (n.getTime()))
 result="ok";
else
 result="notOK";
